camarors8992
- Liverpool, New York
I can't see anything when I am backing up at night and I was wondering how I could wire up an Auxillary light to turn on with my reverse lights to help out. TIA!!
I just mounted a light on my swingarm. I currently am just using it on a switch.5-90 said:Use the OEM signal to "trip" a relay, which feeds a reverse viewing lamp (floodlight of some sort usually works.)
Wire in a toggle switch, so you can override the lamp to OFF unless/until you need it.
5-90
It's a 96.5-90 said:Just tap the wire for the reverse light - a relay will only add a few milliamps of current draw. I'd tell you which wire to look for, but I don't know what year your rig is... You can figure it out with a test light or a meter, or you can look at the back of a lamp socket, or you can give with your year so we can tell you which one is which (I don't have all FSM's, but I'm workin' on it...
5-90
camarors8992 said:30A is more than enough for a single fog light right ? Would too big of a relay be bad ?
solditforajeep said:what method did you use for those lights, mounting and wiring??
53guy said:ever consider wiring the power into the head light switch, so that the light will only come on when its in reverse and the head light is on?
