S Stumpalump NAXJA Forum User Location Franktown Co. Apr 26, 2007 #1 Does the ACOS coil spacer system add to the length of the upper bumpstop or is it the same length as stock?
xjtrailrider NAXJA Forum User NAXJA Member Location Roanoke VA Apr 26, 2007 #2 I've got the ACOS, it adds to the length a few inches as I remember. Someone else may have the exact amount.
X XJING NAXJA Forum User Location Westcoast, Florida Apr 26, 2007 #3 Stumpalump said: Does the ACOS coil spacer system add to the length of the upper bumpstop or is it the same length as stock? Click to expand... The ACOS adds to the length of the coil. As far as bumpstop, you have to ramp it and see how much bumpstop you need.
xjtrailrider NAXJA Forum User NAXJA Member Location Roanoke VA Apr 26, 2007 #4 XJING said: The ACOS adds to the length of the coil. As far as bumpstop, you have to ramp it and see how much bumpstop you need. Click to expand... Yes by 1.25" minimum up to around 5" max but the bumpstop is below where the stop bumpstop were by at least 2" or more.
