- Southern Maryland
Was looking for distributors and found this Accel dual-sync distributor
Not for me but it sounds pretty interesting. Replace the crank sensor. Not sure how/if you could advance the timing with it.
ACCEL 77242, Distributor, DFI Dual Synch, Jeep 4.0, Each
ACCEL's DFI dual synch distributors generate two signals for the cam and crank for sequential fire fuel injected motors. LED readout allows you to sync up without expensive equipment. Billet distributor housing. Uses large cap for better spark distribution.
