AC pressure relief valve
pokeyxj
Albuquerque, NM
So my 01 xj ac compressor would run when the ac was on, after a short time it stops blowing cold air. When this happens the ac clutch is not engaged. Awhile later the clutch will re-engage and there is cold air again. I read the most common problem is low charge. I bought a quick charge kit. When connecting the filler to the low side port there was a small spray of bright green fluid. I thought this might be UV dye from previous owner. ANyway it took the 12oz can of R134. The clutch seemed to stay engaged much longer but would still disengage at times. Next day, start the jeep turn on the AC. The compressor makes this loud moan/grind sound and sprays that bright green stuff out the back through the pressure relief valve. Questions, 1; does this mean the system is over pressurized? 2; should the electric fan come on when the AC is turned on or with just temperature and could this have something to do with the problems? ANy help would be appreciated. Thanks
The compressor cycles normally (on and off) and the cycles can be pretty short, way less than a minute.
The Aux fan comes on as soon as the compressor clutch cycles on, in most models, I doubt yours is any different.
Very short cycles can be an indicator of low refrigerant, though there are other reasons. Guessing, when adding freon can be catastrophic. The best way is to empty and recover the refrigerant, then add a couple of ounces or whatever you need to get the full 20 ounces and then put the whole load back in. It takess special equipment to do it right, you need a recovery system and a means to weigh the charge. The twelve ounces you added is half the total charge, it is likely you way overfilled it. 600 PSI is dangerous, if something blows it can kill you.
Just adding refrigerant can be done with a manifold gauge set, but takes some practice and skill. Not something a novice will likely succeed at, it is pretty much guesswork and experience. The reason being, the pressure in the system is pretty much constantly changing, there are no perfect/exact pressure numbers. The only real constant is the total weight of the charge is 1.25 pounds or around 20 ounces of freon.
Something to keep in mind, more freon doesn't necessarily mean more cold. Also you have to purge the refrigerant line from your freon container to the compressor. Getting the air in the feeder line into the system drives the pressure up, but doesn't help cooling a bit. IMO unless your experienced, it is best to leave it to the professionals and in my experience the professionals screw it up on a regular basis.:)
Found this on a google search.
HIGH PRESSURE RELIEF VALVE
DESCRIPTION
A high pressure relief valve is located on the compressor
manifold, which is on the side of the compressor.
This mechanical valve is designed to vent
refrigerant from the system to protect against damage
to the compressor and other system components,
caused by condenser air flow restriction or an overcharge
of refrigerant.
OPERATION
The high pressure relief valve vents the system
when a discharge pressure of 3445 to 4135 kPa (500
to 600 psi) or above is reached. The valve closes
when a minimum discharge pressure of 2756 kPa
(400 psi) is reached.
The high pressure relief valve vents only enough
refrigerant to reduce the system pressure, and then
re-seats itself. The majority of the refrigerant is conserved
in the system. If the valve vents refrigerant, it
does not mean that the valve is faulty.
The high pressure relief valve is a factory-calibrated
unit. The valve cannot be adjusted or
repaired, and must not be removed or otherwise disturbed.
The valve is only serviced as a part of the
compressor assembly.
Very short cycles can be an indicator of low refrigerant, though there are other reasons. Guessing, when adding freon can be catastrophic. The best way is to empty and recover the refrigerant, then add a couple of ounces or whatever you need to get the full 20 ounces and then put the whole load back in. The twelve ounces you added is half the total charge, it is likely you way overfilled it. 600 PSI is dangerous, if something blows it can kill you.
Something to keep in mind, more freon doesn't necessarily mean more cold. IMO it is best to let the professionals do it ( in my experience even they screw it up often enough). It takes special equipment to do it correctly. If you didn't purge the air from the feeder line from your freon container to the compressor, you just added to the problem, air inside of a refrigerant system drives the pressure up and degrades the system function.
DESCRIPTION
of refrigerant.
OPERATION
Thought I'd give you all an update. Took the jeep to a shop that does the work vehicles. They say the clutch is disengaging put still has power to it, so a worn clutch. They want to replace the compressor. The system was drastically over charged, they adjusted the pressures to specs. The ac get nice and cold while the compressor is engaged. I took the clutch apart, cleaned and reassembled. Seems to have helped. I'll let you know more later. In the meen time I will find a replacement clutch also.
