Hello fellow
'ers!
I would like to get a second opinion as to what my problem may be. This is a 2001 Jeep Cherokee w/ factory radiator / ac / trans cooler.
Background info:
I was driving home this weekend after a 2 hour trip, noticed that the jeep was running about 3/4 of a tick over from 210 when I came to a stop. Didn't think too much about it until I got home and heard a sizzling noise emanating from the front passenger grille area.
Took a closer look and my front bumper / passenger grille was filled with this reddish / brownish fluid. I couldn't really diagnose exactly where it was coming from, but the fluid was pretty runny and didn't quite smell like trans fluid.
I was led to thinking that it was just a really dirty cooling system or a cooling system that the previous owner had run more water than cooling in causing it to get nasty. I haven't touched the cooling system during the year I've owned the XJ as it had never gave me any real problems.
Since I wasn't sure when the last coolant system maintenance / overhaul was... over the course of this week I went ahead and ordered the following:
From everything I was experiencing I thought it was the radiator, but when the AC condenser leaks, it shouldn't be squirting reddish/brownish fluid right? Or am I going insane? The coolant in the overflow bottle looks like doodoo.
Here is a photo of what it looks like:
Regardless, I will be changing out the radiator and the associated components this weekend. I just wanted a second opinion.
Thanks!
Background info:
- New spectra radiator
- New Stant 16psi radiator cap
- Gates 42004 Water Pump
- Stant Superstat 195* Thermostat & Felpro Gasket
- Dayco Upper and Lower Radiator Hose
- Proper disconnect tools for the trans line that goes into the radiator
Thanks!
