A thought on larger throttle bodies. Long
Randre
I've been thinking about larger TB's, I have a 62mm TB and it does make a difference. That along with a spacer changes my torque curve back to where with 31's I don't need to re-gear.
I was noticing that there are also larger TB 's available and that the stock TB's start out at like 60mm ( late model HO) and are necked down a bit and the intake on my 98 is 62mm so it appears that 62mm is a good fit.
Now for the question. According to Bernoulli's principle, as a fluid (or gas) is accelerated (via the venturi effect in the case of a TB) pressure decreases, Boyles gas law states that as pressure decreases, temperature decreases, so a necked down TB will cause a decrease in pressure as well as temperature.
Decrease in pressure is bad hence a larger TB flows more, but decrease in temperature is good so what we get with a bored out TB to 62mm is more flow but a slight rise in temp.
Given this theory, I would assume a TB bored to 62mm to match the intake opening but above the throttle plate bored to something larger would yield better results than a straight through bored TB.
Anybody have another theory?
Randy
Yes, all that is insignificant. The engine has a given amount of air sucking power. A bigger throttle body makes it easier to suck more air = more horsepower. :dunno: :D
I like the newly published "basalt51 Principle". Consider this a "Peer Review".
A carburetor uses this principle to provide a strong signal for fuel metering. I think the throttle body uses the pressure drop across the venturi to provide a strong vacuum signal for the MAP sensor. So, machining out the venturi would reduce the vacuum reading provided to the computer. This would be seen as a demand for more power so the injector pulse width would be increased. The result: richer mixture for more power and lower fuel economy.
I doubt the temp drop amounts to much when the intake manifold is at 175° on a summer day.
The vacuum signal for the MAP sensor is caused by the movement of the pistons down the bores, not by the TB. A larger TB will not adversely affect fuel economy. If anything, gas mileage will be slightly improved because the engine will be able to suck in more air and the A/F mixture will be slightly leaner.
I have a 62mm TB with 62mm TB spacer on my modified 4.0, and gas mileage is better than it was when my 4.0 was stock.
