thanasi85
- Sacramento, CA
1989 with 190,000 it was runnning fine with no leaks an then all of a sudden started spitting oil everywhere and then I noticed water in the oil, so I've pulled the head.
Here are my questions
1. Best way to clean the sludge in the block thats blocking the areas where the oil flows back into the pan. Some of the holes are clean while some of them are backed up with oil and when I stuck a screw driver in them you can feel the thick sludge thats glogging them up.
2. Best local place in Sacramento to take the head in to have it looked at and machined if needed?
3. What would cause the air filter to be dripping wet with oil, the valve cover to start leaking oil all over and oil to be all through the throttle body and intake manifold? PVC valve???
4. Is the rough spot on the cylinder pictured anything to be concerned about?
