triple 4
- Cache Vally Utah
I have a chance to buy an 86 MJ, The Bad part is it does not run and it has a 2.8 with a AX5 and I think a 207 with a CV joint running to the front i. It has 4 Outlaw 2 rims and the body is stright, I'm thinking about parting it out if I buy it. Althought I do not know if it is going to be worth it. It has a good 8ft bed on it, all the glass is good doors and fenders and the rest of the body except the grill are in good shape. The inside doesn't look to bad, but not to good also. It also has a weird lift on it?? It looks like someone pulled the leaf pack apart and put rubber bushings between the leafs? I think it has a D35 in the rear? Also, it has a thing hanging from the frame that looks like it hooks to the rear diff. What would that be?
What do you all think?? Should I or should I not buy this jewel?
Triple 4
Triple 4
