'99 XJ front end/steering issues
Scott Williams
Wilmington, NC
OK, I recently added some .75" spacers to my front 3" Rusty's lift mainly to try and even up the front with the rear. This has created some issues on its own for the front end and steering. I now have a little bump steer (not too bad but noticeable) and also the steering wheel is a little off center. I have not yet had it aligned, as I wanted to make sure I had stuff worked out if I needed to add any hardware...
When we put on the spacers, we added a track bar relocation bracket. I think that thing may be part of the problem, it doesn't seem to fit all that well and the bolts tend to not stay tight. I'd like to know what you guys have done to trouble shoot the front end, get rid of the bump steer, and also what additional equipment I might need.
TIA
i have the rusty's 3" springs but i used the 2" spacer. my bumpsteer was really bad after i added the spacers.
are you running stock ca's
if so you should upgrade to longer ones. and at least one of those being adj. my caster was totally off and i had vibes from the front shaft after my lift. i replaced the lca with longer(rusty's) ones and that helped.
later i added adj. uppers and corrected the caster and vibes.
i think it would be better for the lca to be adj., rather than the uca. but i pieced as i went and this worked for me.
you may want to do your own alignment...without ca's all the shop will be able to set will be toe-in. and with adj. ca's most shops won't know how to adj. them
Lose the relocation bracket and get a adjustable track bar.Mines a 2000 w/ +6" lift and stock steering,no problems!
I prefer the RE HD unit(w/ bracket) over all the others Ive tried
