99 for sale
xj5280
Denver Colorado
Sadly I just can't justify keeping the heep. I'm running out of room for my family to go camping and I just don't do enough wheeling to justify keeping it. My loss is your gain. I know I'm high money wise on CL so for the Naxja crowd I can get it to $5500.
Here is my ad
Selling my 99 jeep cherokee I-6 4.0-AW4 w/168,xxx miles. It has been an ongoing project that I hate to see go but with a growing family I have no choice. Pulls I70 hills great and is averaging between 16-20 mpg. This needs nothing to get in and go wheel 99% of the Colorado and Moab trails.
The good:
- all engine sensors have been replaced and adjusted with OEM equipment and specs
- new upgraded injectors
- new spectre cowl air intake
- newer 3core radiator with aux tranny cooler and new hoses.
- dual battery set up with AGM deep cycle batteries
- 0 gauge battery cables
- starter, alternator, belts, pump, etc. replaced.
- rebuilt SYE transfer case
- new F&R driveshafts from front range driveline.
- new MOPAR fuel pump
Axles:
Front D30 with
currie/savvy off-road 4340 chromoly -500 miles
Synergy HD ball joints -500 miles
New axle shafts with 760 x u joints-new-
New pinion yoke -500 miles
New Timken bearings
4.88 gears professionally installed
New seals and bearings replaced
Eaton electric full case locker -new pin style-
Black magic brake pads
Solid diff cover
Front suspension
5165 bilstein 12" Tavel shocks tuned for the xj weight specific
Poly progressive bump stops
Currie progressive coils -4"
ACOS coil spacers
ANTI Rock sway bar
Rokmen heavy duty adjustable upper and lower control arms
RC drop brackets
Rear axle:
5100 bilstein shocks
4.88
Detroit full case locker
Tires:
33x12.50x15 Duratracs with warranty -~1500 miles on 4 & 0 on spare
Jeep alloy wheels
Alloy USA 1"spacers
Armor :
Front JCR pre runner bumper
Rear JCR swing out tire carrier with roto pax and side protection
ORA sliders welded to uni body frame stiffeners
Gas tank skid 1/4"
Tnt belly skid w/t-case skid
Recovery
- Tow point on all four corners
- Receiver hitch front and rear
- Winch in cradle with quick connect for winching front and rear
Acc:
Rigid dually LED lights up front
Full spare part bin in back corner includes alternator, starter, belts, fuses, sensors, and misc.
raingler netting front and rear.
I'm sure there is a ton more.
The bad:
Cracked windshield
Paint is starting to give
It has been wheeled and has some Rocky Mountain pin striping
Back driver door is not currently opening because of a door handle problem.
The CL link
http://denver.craigslist.org/cto/4500349136.html
