99 5speed to auto swap ?? asap
NOS/86
Any ideas what need to be done ? how doable is this swap ? looking at a xj that is 5speed , but i hate shifting gears . have auto to put in . out of a 97 . give me some info .
thanks
Requires a PCM from an auto. Many OBDII vehicles don't interchange even in the same year and model, but if you get a pcm from an OBDII cherokee and the transmission from that same cherokee it should work.
Not doing the engine swap anymore?
yes doing a swap on the little white 4door that rode aetna with us "randle" .
larry has found me a replacement xj it's a 99 with a 5speed thats out of the truck . i'm going to put the auto out of my 97 if it will work and is not to much trouble to do . this is why i need info ASAP .
have you not heard about larry backflipping and barrel rolling my xj friday morning ??
Yeah I heard about that, just didn't know this was you:)
Sent from my ADR6300 using Tapatalk
Thats what I was thinking too. Either that or just put in one of these http://radesignsproducts.com/14Shiftcontrollers.aspx and skip having to have the auto pcm.
The shift controller would work, and if you want to check one out let me know, I run one in mine.
The other concern I would have is that the 5 speed body almost certainly doesn't have the harness for the auto. There is a high likely hood that the connector is in the main harness to connect with the auto harness, but I don't know that for sure.
