bustedtrigger137
- Woodhaven, MI
98 XJ, 4.0L, AW4, NP231. Bone stock w/Up-Country Package.
It was stalling, mainly in reverse. Unless I give it more "gas", it will jerk and buck. It also will lose revs and stall out while taking hard right turns, as well as going over rough pieces of road (RR tracks, potholes, etc).
I replaced the NSS, thinking that was causing the reverse problem. The original one was cracked, and contacts were bad, but it made no difference in fixing the problem.
Replaced TPS, no difference, same with CPS.
Every time it stalls the Gas gauge goes down to "E" and slowly works it way back up. It seems like it is not getting fuel during this time.
I have searched and cannot find anything similar. I have even un-plugged the TPS, and jumped the pins on the NSS to try and eliminate problems. Any other ideas?
Thanks.
Thanks.
