germanturbo
- OK / AR
looking for the tach output wire on that plug...
germanturbo said:looking for the tach output wire on that plug...
5-90 said:From 1997XJ FSM (1998 should be similar - they're both OBD-II. Distributorless ignition didn't get started, as I recall, until 1999...)
5-90 said:Well then, I get half marks - if it started in 1999 for the WJ, then it started in 1999, didn't it?
I don't suppose you might have caught anything else I missed? It's a chance to update my notes...
5-90 said:Are you sure you can't get your paws on an OBD-II instrument cluster? It would be easier than doing all of this, I'm sure. As I recall, the CCD bus will put out signals to drive all gages, and the IP just ignores the signals it doesn't need...
5-90
