98 Intake Manifold, 99 Injectors, $50each
joshv98xj
Bozeman, MT
I have an intake manifold off of a 98 Jeep Cherokee 4.0L HO that was running when I took it off. It is in good condition, with the expected carbon buildup after 135k. There is nothing wrong with this manifold, I just upgraded. $50.
I also have a set of 6 fuel injectors off of a 99 Jeep Grand Cherokee that was not running when they were pulled. I have no way to be sure they all work perfectly, but they are clean, and have been cleaned with injector cleaner. They have a Mopar part # stamped on them which is:04854181. They have a blue tip and to my knowledge will fit any 4.0L engine from 99-06. Beyond that you will have to check yourself. The specs on them are as follows: 49psi, 22.5lb/hr flow rate. They come with the o-rings for the manifold but not for the fuel rail. $50 for all six. New list price is around $50/each.
