nrwphoto
- Appleton, WI
I have a 98' XJ that has had electrical gremlins in the interior wiring for years. I also have a lack of power and mpg compared to when I first bought it. I have had it into several reputable mechanics and even had the computer reflashed a couple of months ago with no luck. Because I have so much invested in suspension, steering, axles, brand new tires and misc new parts when I decided to move from AZ to MT I loaded the Jeep on a trailer and drug it up here. When I backed it off the trailer I could smell a hot electrical short. Well now it kills the battery in hours and you can pull all the relays and fuses out of the engine control box under the hood and various spots on the motor (CC module, fuel pump and a wonderful buzzing from the bottom side of the fuse box) still have power! :gonnablow::gee::flamemad::huh:
So after letting it sit for a couple of months not wanting to take a loss on all the parts and really not wanting to swap out the whole wiring harness. I am beginning to wonder if I can clear out a bunch of sensors and wires on the engine and convert it to a carb setup. I don't have to worry about emissions/inspections up here so that is no problem. I have read about using a 4.2 intake, Holley or Weber carb, fuel pressure regulator (5psi?) and HEI distributor. Would I need anything else?
Also would the AW4 and gauges (speed, tach, temp, oil pressure) still work if I pull the FI system? Obviously I would leave the above sensors on the motor.
