wishihad1
- charlottesville, VA
hey everybody,
Well Ive got a friend that bought a very clean 97 a few months ago. The previous owner pretty much gave it away because he couldn't get it running right. It had a rough idle, along with a very bad stutter at 45-50 mph if you held the throttle constant. Well we started going through it and the previous owner had did quite a bit of work himself. new plugs, wires, cap, TPS, 02 sensors, etc.
A few weeks ago we did replace the head gasket, which it needed badly after seeing the original one.
While replacing the head gasket we noticed that the number 1 cylinder rockers were really rusted..like I took a wire wheel to them to knock the rust off it was so bad. I didn't really understand how they could rust being covered in oil, but we cleaned it up and put it back together. Well today he goes and pulls the valve cover to check out those rockers, and he sees the one of the push rods on the #1 cylinder has bent, and a small part of the bottom has chipped off.
so...Were thinking this jeep has been running on only 5 cylinders since he got it, and the #1 cylinders push rods haven't been working. hence the reason that the lifters were so rusted.
Would pulling it back apart and replacing that lifter, and a new push rod fix anything, or are we off track here?
