The_Punisher
- Kodiak, AK
Hey folks! I've finally started building my Jeep. I've had other Jeeps and a '92 Chevy I sas'd with tons (5.13's, detroits, 38's). That's my experience level. More than lift kits, I can weld, but I'm not building my own chasis and sh**. I decided to start this to document what I'm doing, and ask questions here, rather than make several threads. I am going to be doing a few things different than most.
I got bit by the go-fast bug while stationed in San Diego. I really enjoyed it before then and was more into fast trail-riding than I was slow technical stuff, but really learned more about it in SD. I am now back in Alaska. Came up with 2 names. Body Shot and SVT-300. Body shot because I box, am a coach and love working the body. SVT-300 is a play on the Raptor SVT, 300 for 300 HP. And my newborn daughter had a serious problem with supraventricular tachycardia which is abbreviated SVT. Her heart rate reached over 300 bpm. So I thought well this Jeep ought to make your heart race
Plan to stencil each on opposite sides.
I had a 2013 Supercharged JKU with about 430 HP, (350 RWHP). It only had 9.5" travel, but good springs/shocks/bumps and it really got it. So I knew where I wanted to go from there. I traded it for a economical VW Diesel which was a blessing in disguise, because I got all my money back from both vehicles after that diesel scandal.
Jeep passes camera here @ 60 mph
https://vimeo.com/110739862
I've always been a fan of Jeep Speed and looked into typical "recipes". I was not able to afford larger than 2.0 fox shocks though. This was something I was always interested in, I've always been a fan of the XJ for the added wheelbase compared to a Wrangler of similar years, lightweight and good "go-fast" parts from the popularity of Jeep Speed.
1997 2wd XJ
AW4
180K miles
ZERO rust, SoCal/East County Jeep.
Bone stock
My Plan:
-11.6" Travel fox shocks front (eibach shock shaft bumps front and rear)
-11.1" rear shocks, largest for stock location. Using the Pythagorean theorem, I was able to figure out that 11.1" travel shocks in the stock location at their angle, would provide exactly 12" of travel.
-HP Dana 44 front/9" rear w/disc brakes
-5.13's
-Detroit rear/True trac front
-33x10.50R15 Toyo MT's
-1.5" front stretch/1" rear stretch (105" wheelbase)
-Short-ish arm w/RE drop brackets
-Deaver coils front/deaver leafs rear
-300 HP 4.7L Stroker with aluminum eddy head (Built by Russ Pottenger)
-AW4 with transgo shift kit/231 with hack 'n tap
-3 link front, mostly by dropping the driver-side UCA
-Building it as light as I reasonably can
-Goal weight of 3500 lbs +/- 100 lbs. 45% front/55% rear distribution
-Read a lot about over-steer so I could design her to want to over-steer more than under-steer. Want it to be easy and fun to kick the a$$ out
-Lots more........
Here are some pics, I have most of my parts. I'm slowly, bit by bit, painting it also.
Upgraded Thunderbird Caliper for the front D44 on the right, has a bigger piston. ONLY $25 off AutoZone! Metal piston too. Also have stoptech cryo slotted rotors and Hawk HPS pads.
Meant to paint hood flat black, prepping between coats, liked the faded look and left it
You can see this blue my wife and I really like. I also like duplicolor bedliner, did the sides and roof.
Wheels/tires patiently waiting in the spare room
Here are the rear shocks, all 4 have those shock shaft bumps. Had these on my JK's Fox shox and they are underrated and under-utilized in my opinion
Painting in the hangar at work. Boss said "you should just paint it in the hangar, we paint our fuc&%$#@ helicopters in the hangar!"
Rear 9". Got a Quick Performance 3rd member (Just so easy and not that expensive), ruff stuff disc brake kit. It has since been painted black.
Started the front axle, this is where it has slowed down
Made my 3 custom links. Lowers are about 19", upper is about 18.5" (obviously adjustable)
Had to clearance the coil/shock brackets. I pushed the axle fwd 1.5" by moving the coil bucket back and more or less putting the coil right over the tube. But now they get in the way of the LCA. Also notice the large washer welded to the LCA bracket. I moved the mounting holes for all of my control arms fwd/aft .75" to gain 1.5" combined, + the 1.5" stretch, to have 3" longer control arms. Might seem crazy, but I was impressed with the "short arms" on my JK and was trying to do what I could to get close to their stock lengths. Almost like a mid arm. Welded 1/4" steel washers from DIY4X to add strength and prevent holes from wallering out.
Lightweight batteries.
Staring, just praying to god it will be enough clearance at max droop haha
1997 2wd XJ
AW4
180K miles
Bone stock
My Plan:
-5.13's
-Lots more........
