jaydee1445
- Orlando Fl
Picked up a non runner 01 2wd Sport project Monday.
Seller clams he did engine swap and it was running fine until trans stopped shifting and then it quit running
Seller says it has a 97 engine.There is no ECU. The Injector / ignition harness has been changed to a 97 type. This harness has the white and black ECU connector so it should be GTG for the 97 ECU.
I plan to buy /FSMAlldata for both years to compare the pinout for the ECU gray connector for compatibility between years.
I'm just throwing this out there to see if the collective has any knowledge of compatibility between the gray ECU connector/ interior harness between the last 2 years and the previous OBDII system.
Any other known compatibility issues for going back to the earlier distributor fired system?
