DirtySouthXJ
- Florida
Hi,
Finally got my 96 4.0 XJ cranking by bypassing the NSS, now it won't start! SMH! The last time I worked on it I was diagnosing the no crank and when I added a jumper wire from the starter relay to ground it would crank and start right up, now not having touched it in a week or two it will crank but not start. I did try starting it with the distributor harness unplugged and three grounds at the passenger side rear block accidently because I had it disconnected while cleaning other harnesses and grounds, but when I plugged it back in..no go. There are two harnesses by the passenger side fire wall that have exposed wires due to the insulation literally crumbling away (one squarish with 6 pins and another that is round inside with 4 round pins), I haven't repaired them yet but plan to tomorrow. I'm in the process of installing an external voltage regulator, replacing the "big 7" with 2 awg and a few other upgrades but hadn't started before trying to start it to move it. Any ideas? I need to get this thing running ASAP to move it. Thank you!
