Juggernaut
- Indianapolis, IN
Been a while since I've been on the site, but we got my wife a 144k '95 XJ SE 4.0 AW-4 231 last week and I am in need of some help. I have been reading through threads non-stop for the last two days and feel like I am beating a dead horse, but I am trying to get this figured out quickly since we are down to one car.
She drove it all week and everything seemed fine. Then, on Monday, she was driving home from work and it stalled twice on her. Luckily it fired up and she made it home. Wanting to see the problem myself, we decided to take it to a friends place when I got out of work. We weren't even out of the neighborhood yet and it stalled. No CEL, no warning. To add injury to insult, it wouldn't restart either. So, we left it for 2 1/2 hours and, when we came back for it, it fired right up and went back in my garage.
Tuesday was my day off, so I figured I would monkey with it some. I got up and ran some Seafoam through the intake as per the can instructions and checked out some connections. Nothing seemed visibly messed up, so we tried to take it to the bmv just down the road. When I got it up to ~45mph and let off the throttle to hold that speed, it started to cut out and come back to life. It stayed running as I slowed down for the stop light, but as we waited for the light, it died. This time it fired right back up. So I turned the corner and it seemed ok until I went to turn right a 1/2 mile later. As I let off the gas to slow for the corner, it died again. So I coasted to the side of the road and tried to start it again. No dice. Came back an hour later and still wouldn't start, so I had it towed home. Later in the day it would fire back up, but, when I let it idle, it would randomly die. It was never a rough stall either, so this led me to believe it wasn't getting spark.
I turned the key and the fuel pump fired up like normal. I pushed the valve on the rail, and fuel came squirting out. This seemed to reinforce my belief that it was spark related. Everything I read pointed to CPS, so I changed it first. No difference. Then I thought maybe it was the IAC or TPS. Cleaned the throttle body and the sensors with TB cleaner (it was filthy); no change. After that, I changed the distributor cap since it is cheap; no change. Next on my list are O2 sensor, coil, or alternator. I don't think it is the alternator since it seems to be charging the battery (dated 7/12) fine. I don't think it is the O2 sensor since I am not getting a CEL. I suppose it could be the coil?
I really don't want to just keep throwing parts at it since it is expensive and time consuming. On the other hand, I can't really test it since it is so random. I feel like I have no choice in the matter but to keep replacing stuff. What say you, the great minds of
