Flamintrash
I’ve got a 95 xj 4.0 aw4 upsized to 2.5inch exhaust with banks header. Just wondering about o2 sensor placement. Been having a stumble and misfire at 3000 rpm’s and when cold start.
Replaced or tested good
All sensors all clean voltage. Ones that were replaced were OEM mopar according to Napa.
vacuum leaks checked none found
Good fuel pressure
Timing good
No exhaust leaks
Injectors new and new pigtails
New air filter
Replaced exhaust gasket and throttle body gasket
Cleaned throttle body
Did change
Horseshoe intake
No cat
O2 sensor is placed right under the oil pan on the exhaust. Could be too far away from header? Anyone got some measurements? Ideas? Racking my brain to find anything else to do besides move the 02 sensor. Motor also only has 8790 miles on it. Trans has 175000 on it. Good clean fluid.
Good fuel pressure
Timing good
No exhaust leaks
New air filter
Did change
Horseshoe intake
No cat
