94 project build
I have dismantled this thing. and built a 4door. all parts from this got swapped over.
the 4door has solid floors, has the same rusty rockers but I'm not concerned with that.
I sold the engine from this 2door for more than I had in the entire build.
Here is the new one 95% complete...
It has custom built adjustable upper control arms.
Rough country fixed lowers
Rough Country quick disconnects
adjustable track bar
ez locker in the front
BIG joint, non disconnect hp 30 ( factory for this as it has full time tcase and HAD ABS)
4.5" front lift coils
8.25 29 spline rear, fully welded carrier, TWO spare axles
YJ e-brake cables ( longer to accommodate lift)
s10 rear spring pack with xj main leaf
I still need to trim the fenders so the tires don't rub, also need to install rear bumper ( factory)
