Replacing my buddies pads,calipers, and rotors on his taurus down here at school and I've run into a problem I've never seen before. I've worked on plenty of brakes, especially discs, but this is different. The emergency cable is like one on a bicycle.(a cable with a slug on the end which fits in a slot). But the slot is on a arm on the caliper which has a spring attached to it. I've got the cable disconnected, but the covering is run through a ear with a hole in it on the caliper. There was a little c-clip that was on there, so that came off, but it won't budge in the whole. Has anyone ever seen a setup like this before? Do I need to just pound it with a BFH to push it through the hole? Pictures tommrow for some help.
Adam
Adam
