93 XJ no Start Fuel issue?
Tonyt22
California
Ok so I have a 93 xj that we had a freak rain fall while I was at work but my hood was up on the jeep at home now I'm having a no start issue getting fuel pressure at the rail 40 lbs it holds for a good amount of time after shutdown injectors are getting 12v with ignition on good spark on all cylinders but jeep won't fire unless I give it a bit of starting fluid but then will run no issues can go on a rough trail run no issues but once I turn it off again won't start unless I use starting fluid again kinda stumped
Even though you seem to have spark, I'd remove the
distributor cap and dry everything out. Condensation can
form after heat/cool cycles and cause intermittent starts...
Yeah, that's the other thing, they will typically cause it to shift all kinds of weird. I just happened to fry one driving in especially heavy rain once, ( a week after replacing it!) so I figured it's worth a try.
