91 xj runs good till wipers are turned on
a4x4freak
Belgrade MT.
Hey guys can you help me my 91 jeep was running badly replaced most all the sensors thought I had it fixed :yelclap:then was on a dusty trail and turned on the wipers to remove some dust and the jeep started running badly again ran bad most of the day (4 hours ) then started running fine so i need to know what to check and why the wipers would make it run badly :dunno:
I would throw a voltmeter on the battery terminals--looking for 12.5 volts static, 13~14.5 volts engine running.
If the voltage is Ok, I would then check the underside of the PDC to see if there is cross-corrosion.
