91 4.0 5 speed
wickedwillys62
thorndale pa
selling this for a buddy he wants some cash to finish his cj7, 91 xj 4.0, ax15, 3.55 gears, 8.25 rear it has about 4" of lift and around 168,000 miles, only rust on on the drivers lower door ut runs great but needs a slave and a fly wheel had new cluth and pressure plate, also need a upper control arm bushing other than that this jeep is in great shape never been wheeled
$1,000
located in thorndale pa
unless the axles or tranny have been swapped in place of the originals it would have 3.07 gears
Vacuum disconnect?
HO? (seems like it, double-checking)
Is it still internal slave?
Why does it need a flywheel/slave? Clutch slipping?
Any pictures of the underside?
Thanks
No didco
Yes HO
Still internal slave
The clutch hooks up great but it engages right off the floor then when its a full runing temp you loose the ability to dissiangage the clutch like someone cut it to much and the slave cant push far enofe im not sure why he thinks the slave is bad we replaced the hole clutch kit just not the fly wheel
