John(XJ)Jeep
- Guelph, Ontario, Canada
I've got a problem with my Cherokee that's got me a little stumped maybe it's the stress of it or whatever but for the life of me I just can't figure out how to fix this problem.
1988 XJ 4.0L 5 Spd.
Under normal driving my Jeep will stutter or stumble around the 2-2.5K RPM, it tends to happen when I don't move the throttle and starts approaching the point where the acceleration is leveling off. It prevents me from having a steady cruise. I've also noticed that it will chase my throttle input when the engine is cold killing my mileage.
It doesn't happen below that RPM in 4th or 5th but it happens more in the 2nd and 3rd gear. I've changed and checked everything from grounds to sensors to vacuum lines. I've re-torqued my manifold bolts and I know I have a cracked exhaust manifold already but this problem started about a week and a half ago, it's been cracked for years. I'm hoping that I've only missed something that is obvious but I just can't think of anything else that is wrong with it. All voltages are around 4.9V hovering between 4.8x to 4.9x volts. I'm gonna pull the sparks plugs and the cap and rotor and take a look at those again, see if I can see a difference in anything again.
If you want to see a small vid of my A/F gauge showing what it's doing the link is this. http://www.youtube.com/watch?v=rdSPF3a50Ng
When it's not doing it the lights stay at green (it's a little rich still) and when it starts stuttering it jumps into yellow (technically where it's supposed to be really) and red erratically and feels like the fuel is being cut.
1988 XJ 4.0L 5 Spd.
