This is a discussed topic on
but, I did not locate much useful for my current conditions. These are:
1 - Driving Xj yesterday and the 4.0L stopped. A cloud of smoke (white) rose up from the hood. I assumed this was unburnt fuel traveling backward in the induction system. Starter continued to crank but, no start.
2 - My prior experience with Renix Xj no starts is that these are due to: 1) bad MAP, 2) bad CTS (near lower left engine mount) and, 3) bad CPS. Presumably, this is just the list of primary reasons for a no start.
3 - Replaced MAP with a used unit. No change; crank but, no start.
4 - Had Xj towed home so at least it's inside.
5 - Verified no spark on Cyl3 this morning.
6 - Performed dynamic CPS test. Measured just under 0.5 VAC when cranking. I concluded CPS is likely to be okay.
7 - FSM contains no indication of how to measure primary & secondary coil resistance. Anyone?
8 - How do we troubleshoot the Ignition Command Module? Check I/O with meter?
9 - What about an ignition relay? The FSM is lacking in this regard too.
10 - Obviously, I cannot rule out the ECM either (at this stage).
Any help is appreciated (especially today...).
Rick
Rick
