- Camden, SC
Looking for some MJ specific help here. I have an 88 that the column was sloppy on. Well I tore it down and tightened the annoying bolts in it. When I put it back together shortly after the ignition quit moving freely. So I tore back into it and found the rod bent. I pulled a column out of a parts xj and the rod is completely different. Is it possible I basically bent the rod straight? Anyone have a column out that can post pictures of how the rod goes in the switch and how the switch mounts on the column?
Pictures are posted on CC.
https://comancheclub.com/topic/54815-88-mj-tilt-column/
