88 Mj chassis connector wires (C157?)
AIbandit
Chico, CA
I'm trying to combine the chassis harness from an 88 mj to the dash harness of an 89 cherokee.
I have an image of what I believe is the correct connector on the 88 but need to know the wires, can't find them specified in the diagrams.
I believe Orange is Pump hot, tan is fuel sender. No clue about the rest.
Got the comanchee side thanks to Ohm on comancheeclub
You should double check this. C157 Body harness side.
From right to left.
A: Right Stop/Turn
B: Tail lamps (running)
C: Fuel gauge
D: B/U lamps
E: Left Stop/Turn
F: Fuel Pump
