They didn't use a BOV. It is just a 1 inch bung for that hose that routes from the charge pipe to the bypass valve inlet. Kind of like how the stock Thunderbird setup was just way shorter.
Here is what I think. As long as the vacuum line for the bypass valve actuator is routed to AFTER the throttle body(Intake manifold), It will see vacuum as soon as the throttle closes and open the bypass butterfly fairly quickly even if there is still boost in the charge pipe. The question is how fast does does the intake manifold go from boost to vacuum after the throttle is closed. If it is almost instant then it might be safe. If it is a few seconds then that may be not a good idea and too much pressure will be on the throttle plate.
A BOV would be the best way to do it for sure.
