crawldaddy
NAXJA Member # 1491
- Alameda, CA
This is getting worse.
Engine hesitates for just a tiny fraction of a second, just long enough to cause the drive train to shudder - an uncomfortable bump.
Often happens about 1/2 second after moving away from a stop under mild acceleration.
Less often when slightly decreasing throttle after steady speed.
New items within last month include: T-stat, plugs, cap, rotor, O2, cat, smog on dyno passed CA no problem. visually inspected vacuum system - Aok.
There seem to be numerous threads about hesitation, but none of them put their finger on what seems to be a common problem that feels like it should have a simple fix.
