Does anybody know what transmission came behind the 2.1L Renault Turbo diesel engine in an 87 cherokee, especially if it has the "jeep" bellhousing pattern or not? Any info on this motor is good info.
Mine came with an Aisin AX5. The input shaft is longer for the diesel application. I believe that the rest of the transmission is common. I believe the turbo diesel with an automatic would be a good combination. The reason is that the automatic keeps the turbo spooled up as you never let your foot off the gas to shift. I believe that is why the Grand National did not have a standard transmission as an option.
correct, I've here some 2.1td and some 4.0 the bell housing is completely different.
There are three version of bell housing AMC, Renault and VM all are different.
The 2.1 bell housing is prone to broke on the starting motor support, I've reinforced it on my one
The bell housing of 2.5TD VM having the same bolt pattern of the 3.1TDi VM used on grand.....
Also the driveshafts are different (shorter in front longer in back) the combination 2.1+AX5+231 is shorter than 4.0+AW4+242
