If the fenders from the '85 are like my '89, then the header panel will attach using studs in the fender and nuts on the header panel. On the '92, the header panel should attach with the studs on the header panel and the nuts on the inside of the fender. I don't think it would be all that difficult to drill the holes for the header panel studs, and if you want to go the opposite way, just use self tapping screws and a fender washer to retain the header panel.
