I just picked up this 84 XJ, and have been trying to get her up to snuff.
One of the problems I have is that the crossmember bolts are broken. By that I mean that they appear to be studs and have broken loose from whatever they were welded to.
I am not sure how to go about fixing that problem. 2 of the four bolts are snug, but two are broken loose from their normal spot.
There is no way to get to the other end to re-weld them because they are inside the frame tube?
Any idea how you fix something like that?
