Jeff 98XJ WI
- Butternut, WI
I'm planning to build a rear HP 60 with Disk brakes and am going to be using front Ford 60 hubs and spindles on the rear. I want to set it up for using rear disk brakes and want to know what those that have some experience with this would recommend? I see kits on ebay for stock rear 60's and 14 bolts and they appear to use Chevy D44 8 bolt rotors with large GM calipers. I believe the large GM calipers are the same units that are used on GM front Dana 44's, right? The GM 8 bolt rotors that I've seen used are the ones with little cutouts around the hat. I believe Napa 85677 is this rotor. http://www.napaonline.com/MasterPag...677&Description=Brake+Rotor+Only+-+Left+Front
Here is the Napa 85731 Ford Rotor. http://www.napaonline.com/MasterPag...731&Description=Brake+Rotor+Only+-+Left+Front
Now, when I compare the Chevy rotor to a Ford 8 bolt D60 rotor they seem pretty darn close. Thickness seems comparable with a discard thickness of 1.18" for the Ford Rotor and 1.215" for the Chevy rotor. This is about 1/32". Diameter of the Ford part is 12 9/16" and for the Chevy is 12 1/2". Rotor height is a little more for the Ford unit at 3 7/32 with the Chevy unit being 2 13/16". The difference is about 3/8". Cost is about the same. So, it seems like I might as well use the Ford rotor since it is designed to fit the Ford hub.
As for calipers, the Ford dual piston units are a bit more expensive than the Chevy single piston units: http://www.napaonline.com/masterpages/NOLMaster.aspx?PageId=430&CatId=3&SubCatId=13
Here are the Chevy units: http://www.napaonline.com/masterpages/NOLMaster.aspx?PageId=430&CatId=3&SubCatId=13
I could use a stock Ford caliper mount with Ford calipers. Or, I could combine the Ford rotor with a weld on caliper mount and the Chevy calipers and I should have decent stoppers on the rear. Oh, at this point I am not worried about mechanical parking brakes on the rotors. Any information/ opinions/ thoughts would be appreciated. Jeff
