8.8 finally in.
jpcherokeekid
north
So i finally got around to instaling my 8.8 which has been sitting in my patio for about 6 months. the install went fairly easy as i had already regeared it 3 months prior, so all i had to do was grind the mounts off and weld new ones on. i also swaped in a proportioning valve off a grand cherokee with four wheel disks so my brake will work properly now. all i have are post instal pics as i forgot to bring my camera with me this last weekend. so here is how she sits now, ive gained another inch or so to help level the back out to about 6in now. the axle has 4.11 yukon gears, custom bent brake lines and a factory LSD. i still have to modify the stock ebrake cables to fit and then it will be done.
looks good other than the tire size. i just installed mu 8.8 as well. now running 35's LOVE EM!!!
yeah ill be getting 33's soon, i hope but reusing the shock mounts was easier and cheaper than buying new ones, plus it keeps my shock length the same.
Looks good. You're going to wish you'd raised those shock mounts though!
Hale
