GrimmJeeper
- Gardena, CA
ive got a 86 astro van with a 700R4 in it. yesterday it clunked really loud while sitting at a stoplight and killed the motor. i started it right back up and it wouldnt move. i can move it through the gears and its like im not doing anything, no RPM change on the motor, nothing at all happens. i dropped the pan today to see if something had come loose inside, but it looks fine, the fluid is clean and not burnt, the shift selector is moving the piston through the valve body just fine.
anyone have experience with these transmissions? im just wondering what could have caused it to act like this. i'd like to avoid taking it to a trans shop without figuring out what is wrong with it first. i was thinking maybe the pump went out on it or maybe a problem with the coverter.
help!
thanks
-G
help!
thanks
-G
