Can anyone recommend where I can buy an affordable bored out and butterflied 62mm TB? Ideally, someone who will also refund me $ if I send them back the core?
Waste of money unless you have an engine capable of additional flow.
Put a throttle body spacer on instead. It’ll give you about the same kinda HP.
It’s a jeep not a Ferrari.
Throttle body spacer are absolutely useless unless using a TBI set up.
Bored throttle body is one of the only "power adders" that works. Now whether it's worth the $300 or so for the 5-10hp you get, is up to you.
You can get about another 20-30hp with a proper intake, bored tb and exhaust set up. Upgraded ignition system will help it rev and run smoother but won't add power due to the 4.0 computer compensating for the change.
