60mm Throttle body $40
markaboo929
Mooresville,NC
I am upgrading to a 63mm T Body for my stroker.I should have it by this Saturday,I hope.I am selling the current 60mm one on my engine now.$40...IF you want it shipped...calculate using USPS flat rate medium box.Thnaks
I can meet some where not too far from where you/I am located..:patriot:
Sorry ,forgot to mention that.91-95 it does not have provision for the map sensor.You can however use a different source for the map sensor as I have mine that way.A 99 + manifold has a vac port right under on the side where the T Body bolts to.
