I haven't posted up on this build for awhile, but there has been some progress. After the wiring was finished, of course I wanted to drive the damn thing. That began the clutch disengagement fiasco. Long story short the trans came in and out three times, I lengthened the throwout bearing arm pivot. I threw an old extension on the lathe and made it long enough for the arm to be in its forward most position in the bell housing hole.
Then I ended up swapping to a Wilwood master and finally swapping out the pressure plate to arrive at a functioning clutch. Lord have mercy. I then started on the brakes, after some digging I found out that the owner of the Wagoneer that I got the axles out of used '85 Lincoln Continental calipers when he did the rear disc brake conversion. Threw some new calipers and pads on as well as a new master, which I couldn't resist throwing in the powder oven.
My brother came over Friday and started on the exhaust system, just a simple 2.5" dual into a single muffler to a 3" tailpipe. Threw a bunch of V-bands on it for good measure and this is how it sits.
Kind of reminds me of BMW exhaust with the pipes running parallel like that. Pulled the springs out today to check clearances at bump and compression
Here it is all hunkered down. The track bar hits the oil pan at this point, but the bracket on the frame side needs to be lowered to put the drag link and track bar parallel. Once that is done I'll decide if I need to put a bend in it for ultimate clearance. Either way I will be bump stopping it so I won't have to worry about cracking that oil holder when I come down from some air borne fun.
Here she is at full droop, you can clearly see that the links aren't parallel, hello bumpsteer. I'm thinking that I will end up using a 14" travel shock or coilover. Not too excited about the hit that will have on my wallet though.
