You know how I feel about my LS, so I won’t try (too hard) to talk you out of the Mopar swap. I am fairly ignorant in the emissions department, as we don’t have it here. But, from what I read a lot people do the LS swaps because of the ease of passing the test. If all they do is plug into the OBDII port it won’t matter as long as it reads clean, right?
Unfortunately I believe not only will it have to read clean be it will need to be from a vehicle at least as new as 1998. For a LS motor that wouldn't be a problem, but for a 5.0L it would be. The 5.0L is out for now though so that's not an issue. I'm not positive what their reaction would be if the motor was from another manufacturer or from a truck.
I see the earlier 5.3L engines pretty cheap around here. Of course there is an adapter to make your 241OR work, but it’s kind of pricey. Or you could sell the 241OR and use a 5.3L/4L60e/NP241 all from the same donor. If I were to do it again I would pull the engine, tranny and t-case from the same vehicle, instead of adapting my 231J to work.
A GM 241 would be fine. 4:1 low is nice but it's not really the night and day difference I thought it would be. I really went to the 241OR for strength reasons over the 242 I had. After breaking the 4th 242 I was ready to move on just as I am now with my motor.
Your picking a fight here, ask me how I know. Actually, I’m surprised you only got one response. I guess it’s still early in the discussion
Yes I know. I'm just really frustrated at this point with my 4.0L's. I know so many people have had great luck with them but I have not. Plus, since I have towed with this XJ since new power has been a bigger issue for me since new than it would be for most people. Besides the lack of HP for towing I have had a misfire nearly since the Jeep was new. At first it was only after heat soak which the dealer could never remedy, for the last few years it's been pretty constant, and my wife's '01 has the same issue. As a mater of fact, that problem along with a CD player problem is how I found
way back in '99.
Using fuel economy for a reason to do the swap is a joke really. Yeah, you could baby it and get 18 mpg, but who is going to do that? I have been trying to baby my way through tank of gas for over a year to see what I could get for mpg’s; I haven’t been successful.
Fuel economy certainly isn't the reason for the swap but it is the reason I'd prefer to keep the motor smaller than larger. I'd assume a 5.2L would get better mileage than a 5.9L so for me it seems like a better choice. The cool part is that if the 5.2L doesn't do the trick some day down the road a 5.9L could easily be swapped in. But I don't foresee that being an issue.
Much like my swap, the reason for the intense amount of work had a lot to do with timing. There was very little aftermarket/web-forum support when these were done. It's pretty much cake these days.
