4x4 conversion
jeepmark2x4
georgia
I have a 94 jeep grand cherokee and i want a 4x4. I need information on this swap, im mechanically capable of doing this ex. ive done...auto to manual conversion, rear ends rebuilds
I just need what parts are needed and which parts can be used from the 2 wheel drive front end.
The only parts you can use from the front end are the control arms, tie rod and drag link. And springs and shocks, of course, unless you plan to lift at the same time you convert to 4WD.
By the way, since this post isn't about an XJ or an MJ, it belongs on the "Other Tech" forum.
