4 Cyl instrument cluster w/tach - NOS
rsalemi
New 4 cyl instrument cluster with tach - fits 87 to 90, may fit 84 - 86? This is a Metric cluster - you need/should/may plug in your US spedometer and could change your temp and oil pressure guages if you wanted to. Cluster without spedo $35. Complete Metric cluster with spedo $45 plus shipping from RI 02824
Just a note for anyone looking at this cluster, the tach reads the same for the 4cyl as the 6 cylinder. I ran into this when I made a change in the tach circuit of a 6 cylinder tach to make it read correctly for the 4 cylinder and it ended up off. The tach output is the same for the same rpms between the 4 banger and the 6. Go figure.
Tom Houston
Loveland, Colorado
