montocr
- Washington
And what is Yukon's address, and where is their factory?
yeah, because Yukon and Superior make their own gears.
And what is Yukon's address, and where is their factory? I assume you are being sarcastic?
Hell now you need to grind the gears, just to put 4.56s in.
This really isn't a big deal, many axles require notching the gears when running a deeper gear set. Because of the nature of a hypoid gear set, at no point is all the force applied to an individual tooth. Therefore, strength is not an issue. Besides, it only takes a minute to grind the tooth enough to slide the pin in.I thought the reason nobody made 4.88's was because of clearance issues with putting the corss shaft back in the carrier. If you made c-clip elimator kit for the 8.25, then I could see 4.88's being possible. Hell now you need to grind the gears, just to put 4.56s in.
I am not worried about the grinding of the teeth on the ring gear effecting strength. It was more of a clearance issue. Just how much would you have to remove to slide the cross shaft in? If there was a c-clip eliminator kit for the 8.25, which I have look into designing and developing myself. Capital is my only hang-up, the design work is done. You wouldn't have to worry about the cross-shaft at all and you could develop pretty much any ratio that the gears could handle, 4.88, 5.13, 5.38 etc.
I am glad somebody has finallly taken the steps to develop and manufacture 4.88's for the 8.25. If they were available when 4.88 came for the Dana 30, I would have gone with those in a heart beat instead of my 4.56's.
C-clip eliminators dont have a real good track record for reliability and typically require permanant modifications to the housing. I do see some benifit of bolt in vs. c/clip, but grinding the gear is proven to be OK, so no need to develop something solely for this reason. Remember 4.56 have been around for a long time and also require grinding. This is common in many diffs. Some ford diffs even require grinding at 3.73!
apparently nitro gear and axle doesnt have a website, and if they cant get a basic website up, i sure wouldnt trust them to make gears.
You have to have the pin out to install the c-clip axle shafts, and you can't exactly remove the ring gear with the carrier installed.I don't really see why, just remove the ring gear and slide the pin in and be done with it.
-Alex
I had to have a tooth ground down a bit when the shop install 4.56s in my 8.25.Wait a second, I don't remember doing any grinding when installing my 4.56's in my 8.25, can someone else verify that this must be done with 4.56 and 4.88? I don't really see why, just remove the ring gear and slide the pin in and be done with it.
-Alex
