4.5" lift - what caster?
Jeep450r
Nor*cal
I'm trying to track down my faster problems and am working with my caster now. I am lifted 4.5" running 33's. What should I set my caster at? I have heard anything from 2* to 7*. What would be optimal for a DD?
Also what is the calculation to figure out your true castor angle from the diff cover angle?
...Also what is the calculation to figure out your true castor angle from the diff cover angle?
I'm pretty sure it's 6-7 degrees... But you may have to sacrifice some caster to save driveshaft angles.
To check it from the axle google "go-jeep". he has a page about checking angles.
