4.0 swap '00 in a '97 (help!)
pencilrunner
Herndon VA
Hey y'all, need help on something.
Got a '97 with a cracked head (0630 stamp) and a ton of coolant in the oil. I'd be risking it with the bottom end bearings, for sure, without doing a replacement of these, too.
Also have a '00 with a good engine. Would like to just swap the engines.
'00 has the coil pack, '97 has the dizzy. Can I simply install the dizzy, etc, in the '00 engine and drop it in?
Thanks, everyone. On a serious budget here, for sure.
Yes, the motor doesn't know what year it's going into.
Assume the 0331 head is suspect, and replace it with a junkyard part that has been inspected. That NC4x4 engine swap posting has some major errors, and incorrect assumptions, but the basic info is any XJ/ZJ/YJ 4.0L block will interchange.
