MJlogan
- Upland, CA
Renix motor
240k mi.
About a month ago the jeep started loosing power when I was just cruising along to the point where I had to hold it wide open to get it off the road in first gear. Then it would not even idle at full throttle. I could hear what sounded like a compression leak in its last minute or so of running. I figure it needs a headgasket or the head is cracked since the motor has about 240k on it.
Get the head back from the machine shop. Machinest said the head was a little warped but not too bad. Slap it back on, hook everything up and it wont fire. Hold it wide open while cranking and I got it to fire but it only runs at about 400rpm at full throttle. As soon as I back off, it dies. Still has the compression leak sound just like when it died before the new headgasket.
Here are my ideas:
fuel pressure regulator
some sort of egr problem
timing off somehow
I'm going to pick up a fuel pressure regulator at the junkyard and clean out the egr next weekend. Anyone expirienced this before or have any ideas?
240k mi.
Here are my ideas:
timing off somehow
