FUNKYTEE5
- Vancouver, Wa.
I have started seeing slightly erratic oil pressure readings on my 4.0. I have read some accounts where people have stated that the oil pumps are prone to wearing out around 150k or so. I just turned 144k. 20k ago it had 80psi cold and never went under 50psi warm. Now it's 50 cold, and never goes above 50psi warm (10w-40) and idle has dropped to 25psi warm. I'm suspecting that it may be a worn out bypass spring? If the mains were loose then it'd drop pressure under load right? Any oil pump's to avoid? Thanks for input.
FUNKYTEE5
FUNKYTEE5
