37's 38's on a DD, FW axles
csudman
Statesville, NC
I've done a search but haven't found my exact answer. I'm up grading. Doing a 9" 31 spline rear, Detriot. Not sure on the front yet, either 44 or d60. Either way I realizer this means new steering of some kind. So here's my ques.
1. Is this even viable as a DD. I have 8" longarm and will space to 9" Is anyone else running this setup as a DD?
2. Steering Solutions? Brace the snot out of my stock box, build a partial subframe for it, and run xover? Or other ideas?
3. 37" Boggers offroad, 38" BFG AT's on? Good combo?
4. 17" wheels with alot of BS although I want the width for stabitity offroad. And chick factor!!
5. Opinons on best, toughtest, easiest, and cheapest front end option. (I realize most of those words don't go together)
Thanks in adavnce Fellow Jeepers
didnt know they made 38" all terrains now..
you better beef the crap out of the steering :)
toughest, easiest front end would be a HP driver's drop dana 60 from a ford, but they are hard to find...
44s are easier, and might handle it OK if you arent stupid with the go-pedal.
